주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. Eufy Doorbell 2k (Battery-Powered) 수리는 자사의 서비스 설명서를 사용하세요.
  1. Eufy Video Doorbell 2k (Battery-Powered) Teardown, Eufy Video Doorbell 2k (Battery-Powered) Teardown: 1 단계, 이미지 1개 중 1개
    • Using Phillips 000 screw driver remove 8 screws at the back.
  2. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 2 단계, 이미지 1개 중 1개
    • Using a metal or plastic prying tool, insert it in between the seems. Then carefully lift the back unit out. Once one side is open simply lift it out from the front cover.
  3. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 3 단계, 이미지 3개 중 1개 Eufy Video Doorbell 2k (Battery-Powered) Teardown: 3 단계, 이미지 3개 중 2개 Eufy Video Doorbell 2k (Battery-Powered) Teardown: 3 단계, 이미지 3개 중 3개
    • Battery is connected to the main board. Using a tweezer remove the battery connector.
  4. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 4 단계, 이미지 1개 중 1개
    • Water manage to get into my unit and fried this chip. Suggest you use a rain cover if this doorbell is expose to weather outdoors. There are a lot of 3D printed rain covers for this doorbell.
  5. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 5 단계, 이미지 2개 중 1개 Eufy Video Doorbell 2k (Battery-Powered) Teardown: 5 단계, 이미지 2개 중 2개
    • Remove 4 screws with a Phillips 000.
    • Remove 2 screws with a Phillips 0.
  6. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 6 단계, 이미지 1개 중 1개
    • Disconnect the connector.
    • CCD of the camera
    • Do not touch the CCD. If finger prints got stuck it will be difficult to clean.
  7. Eufy Video Doorbell 2k (Battery-Powered) Teardown: 7 단계, 이미지 2개 중 1개 Eufy Video Doorbell 2k (Battery-Powered) Teardown: 7 단계, 이미지 2개 중 2개
    • Battery details and specification.
    • You can use a multimeter to check the voltage of the battery. Mine was still good at 3.9V. Unfortunately the chip got fried.
작성자
1다른 기여자 명과 함께
Muzaffar
회원 가입일: 05/12/19
165 평판
안내서 1개를 작성함
12가이드 댓글
Goodacternoon po Maam/Sir?
pwedi poba mag order board lang
LAMPUTE VENT - 답글 공유
And what happends next?
kubakumate - 답글 공유
This is great. Any suggestions for sourcing a new battery pack?
Tezza - 답글 공유
My battery may be shot. Same as in pics. Where can I get a replacement?
Joe Guy - 답글 공유
I tried changing the battery in mine. Got it sourced individual cell and attached to the existing points (by removing old cells). It got really hot. Seems my chip got fried as well. Not sure how to check if there is anything else faulty than BAttery Chip?
Rishi Gaurav Gupta - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 53
지난 30일: 269
전체 시간: 8,823
