부품
부품은 필요하지 않습니다.
  1. Make sure that your vacuum is unplugged from a power source. Press the black button just below the handle and extend the pole fully.
    • Make sure that your vacuum is unplugged from a power source.
    • Press the black button just below the handle and extend the pole fully.
  2. Press the black separator switch to separate the top and bottom halves of the vacuum. Press the black separator switch to separate the top and bottom halves of the vacuum.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown. Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing. Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  5. Pull out the button and the spring attached to it.
    • Pull out the button and the spring attached to it.
    • Swap the old spring with a new one.
  6. Insert the new spring and button back into the right slot as shown in the picture.
    • Insert the new spring and button back into the right slot as shown in the picture.
결론
Nikhila Vijaybhaskar
회원 가입일: 2013년 09월 24일
224 평판
안내서 2개 작성하였습니다
University of Maryland, Team 1-1, Gulbrandsen Fall 2013 University of Maryland, Team 1-1, Gulbrandsen Fall 2013 회원
UMD-GULBRANDSEN-F13S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 195
