주요 콘텐츠로 건너뛰기
Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement
필요한 것
  1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement, Brush roll: 1 단계, 이미지 1/1
    • Unplug the vacuum from the outlet.
  2. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 2 단계, 이미지 1/1
    • Use a damp paper towel to clean the bottom of the vacuum of any debris.
  3. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 3 단계, 이미지 1/2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 3 단계, 이미지 2/2
    • Flip the vacuum over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 3.0 mm screws.
    • Use a Phillips #2 screwdriver to remove the two 4.2 mm screws.
  4. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 4 단계, 이미지 1/1
    • Pull the bottom and top cover of the brush roll compartment apart.
    • Internal components of the vacuum may fall out during this step, so keep track of where they are located for reassembly.
  5. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 5 단계, 이미지 1/3 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 5 단계, 이미지 2/3 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 5 단계, 이미지 3/3
    • Lift the brush roll out of the vacuum.
    • The brush roll is connected to two white placeholders on both left and right sides. To remove these, pull them away from the brush roll.
  6. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 6 단계, 이미지 1/1
    • Thoroughly clean the inside of the vacuum with a damp paper towel and let it dry.
  7. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 7 단계, 이미지 1/2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 7 단계, 이미지 2/2
    • To replace the brush roll, attach the two white placeholders on both ends of the brush roll and set them into the corresponding slots.
    • The slots are located on the left and right ends of the bottom cover.
  8. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 8 단계, 이미지 1/2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 8 단계, 이미지 2/2
    • Reattach the cover and screw it back into place using a Phillips #2 screwdriver.
    • The two 4.2 mm Phillips #2 screws go in the two middle bottom holes.
    • The four 3.0 mm Phillips #2 screws go in the side holes.
결론
Plug in your device and test it to ensure that you have reassembled it correctly.
Mark Parala
회원 가입일: 08/23/22
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-8, Briggs Fall 2022 CSU Los Angeles, Team 1-8, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 55
전체 시간: 807
