주요 콘텐츠로 건너뛰기
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
필요한 것
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: 1 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: 1 단계, 이미지 2/2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 3 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 3 단계, 이미지 2/2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 4 단계, 이미지 1/1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 5 단계, 이미지 1/1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 6 단계, 이미지 1/1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Celina Burchett
회원 가입일: 10/13/14
1,122 평판
안내서 8개 작성하였습니다
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 회원
CLEM-BENSON-F14S2G2
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 30
전체 시간: 12,045
