소개
If you determine that your vacuum brush roll will not turn and produces a burning smell, this guide will help you to replace the brush roll.
필요한 것
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - 답글
