주요 콘텐츠로 건너뛰기
Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement
필요한 것
  1. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: 1 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: 1 단계, 이미지 2/2
    • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  2. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 2 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 2 단계, 이미지 2/2
    • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  3. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Accessory Holder: 3 단계, 이미지 1/1
    • Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
  4. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 4 단계, 이미지 1/1
    • Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Celina Burchett
회원 가입일: 10/13/14
1,122 평판
안내서 8개 작성하였습니다
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 회원
CLEM-BENSON-F14S2G2
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 667
