주요 콘텐츠로 건너뛰기
Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement
필요한 것
  1. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: 1 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: 1 단계, 이미지 2/2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 3 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 3 단계, 이미지 2/2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 4 단계, 이미지 1/1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 5 단계, 이미지 1/1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 6 단계, 이미지 1/1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
  7. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 7 단계, 이미지 1/3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 7 단계, 이미지 2/3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 7 단계, 이미지 3/3
    • Remove the belt from around the motor.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Celina Burchett
회원 가입일: 10/13/14
1,122 평판
안내서 8개 작성하였습니다
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 회원
CLEM-BENSON-F14S2G2
4 회원들
안내서 18개 작성하였습니다
댓글 5개
It was Too hard So went to stretch the belt then it was on
missouri river production - 답글
To reassemble was not available for me so I kind of did it myself but I'm having trouble getting it back on straight
eternallight6 - 답글
i have read every sticker on this vbacuum read several maintenance steps …. i mean DA remove four screws …huh.
now can someone tell me whart size belt to get from the store
Sara Leinen
sparkplugkitten@msn.com
Sara Leinen - 답글
I got it used. I turned it on it worked. Then it just turned off and want come back on some please help me
nickietucker81 - 답글
Where's the trouble shooting
nickietucker81 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 48
전체 시간: 48,078
