주요 콘텐츠로 건너뛰기
Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement
  1. Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement, HEPA Filter HF16: 1 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement, HEPA Filter HF16: 1 단계, 이미지 2/2
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement: 2 단계, 이미지 1/3 Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement: 2 단계, 이미지 2/3 Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement: 2 단계, 이미지 3/3
    • Twist the exposed, black HEPA filter cover, found underneath the removed dust cup, to the left (counterclockwise) until it releases.
  3. Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement: 3 단계, 이미지 1/1
    • Pull the grey handle on the HEPA filter to remove the used HEPA filter.
  4. Eureka AirSpeed Bagless Zuum Vacuum HEPA Filter HF16 Replacement: 4 단계, 이미지 1/1
    • Place new HEPA filter into holder.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Celina Burchett
회원 가입일: 10/13/14
1,122 평판
안내서 8개 작성하였습니다
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 회원
CLEM-BENSON-F14S2G2
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 33
전체 시간: 2,083
