주요 콘텐츠로 건너뛰기
Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement
  1. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: 1 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: 1 단계, 이미지 2/2
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: 2 단계, 이미지 1/2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: 2 단계, 이미지 2/2
    • Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup.
  3. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: 3 단계, 이미지 1/1
    • Remove the white filter by lifting the gray foam filter handle.
  4. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: 4 단계, 이미지 1/1
    • Push the white mesh, segment below the filter handle downward so it pops out of the grey filter holder. This will remove the filter.
  5. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: 5 단계, 이미지 1/1
    • If filter is unable to be washed, place a new filter in gray holder.
결론
Celina Burchett
회원 가입일: 10/13/14
1,122 평판
안내서 8개 작성하였습니다
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 회원
CLEM-BENSON-F14S2G2
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Can you wash the white filter within the grey holder?
Lloyd C - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 38
30일 전: 157
전체 시간: 13,397
