주요 콘텐츠로 건너뛰기
Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement
필요한 것
  1. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: 1 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: 1 단계, 이미지 2/2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: 2 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: 2 단계, 이미지 2/2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 3 단계, 이미지 1/3 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 3 단계, 이미지 2/3 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 3 단계, 이미지 3/3
    • Pull up and unhook the two front tower latches using two fingers. These are located at the base of the tower.
    • Pull up and unhook the latch on the back of the tower.
    • Firmly lift the vacuum tower up and out of its stand.
    • The exhaust filter cover can be replaced once the tower is removed. It will not affect the steps.
  4. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 4 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the four 20mm screws on the top of the vacuum head's cover using a JIS 1 screwdriver.
  5. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 5 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 5 단계, 이미지 2/2
    • Turn the vacuum head so that the back is facing you.
    • Press the handle release pedal.
    • Rotate the top of the motor cover down while pressing on the pedal release.
    • The motor cover should rotate from an upright position back towards the ground, as it would if the handle were still attached.
  6. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 6 단계, 이미지 1/3 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 6 단계, 이미지 2/3 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 6 단계, 이미지 3/3
    • Locate the two tabs on the back of the cover.
    • Pull up on the tabs and lift the cover away from the device.
  7. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: 7 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: 7 단계, 이미지 2/2
    • Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
    • Remove the two 20mm screws using a JIS 1 screwdriver.
  8. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 8 단계, 이미지 1/1
    • Lift up on the belt latch assembly and remove it from the vacuum.
결론
Grayson Clendenon
회원 가입일: 10/02/17
571 평판
안내서 5개 작성하였습니다
Cal Poly, Team S4-G5, Livingston Fall 2017 Cal Poly, Team S4-G5, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G5
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 836
