주요 콘텐츠로 건너뛰기
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: 1 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: 1 단계, 이미지 2/2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: 2 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: 2 단계, 이미지 2/2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: 3 단계, 이미지 1/1
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: 4 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Filters Replacement: 4 단계, 이미지 2/2
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: 5 단계, 이미지 1/2 Eureka SuctionSeal 2.0 Pet Filters Replacement: 5 단계, 이미지 2/2
    • Pull up on the tag and remove the filter.
결론
Anna Snyder
회원 가입일: 10/02/17
336 평판
안내서 3개 작성하였습니다
Cal Poly, Team S4-G5, Livingston Fall 2017 Cal Poly, Team S4-G5, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G5
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 590
