주요 콘텐츠로 건너뛰기
Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement
필요한 것
  1. Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement, Handlebar: 1 단계, 이미지 1/2 Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement, Handlebar: 1 단계, 이미지 2/2
    • Use a 5mm Allen wrench to unscrew the brakes.
  2. Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 2 단계, 이미지 1/2 Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 2 단계, 이미지 2/2
    • Unscrew the stem-bolts using a 4mm Allen wrench and remove the faceplate and handlebar from the stem (hold the handlebar as this step is done).
  3. Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 3 단계, 이미지 1/1
    • Clean the faceplate cover with a cloth.
  4. Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 4 단계, 이미지 1/1
    • Replace the faceplate with the bar on the stem, and screw down the bolts evenly using a 4mm Allen wrench.
  5. Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 5 단계, 이미지 1/2 Eurobike X1 27.5 Inch Mountain Bike Handlebar Replacement: 5 단계, 이미지 2/2
    • Reinstall the handlebar controls (breaks & handle grips).
결승점
Guled Omar
회원 가입일: 09/10/21
121 평판
안내서 1개 작성함
York University, Team G-1, O'Regan Fall 2021 York University, Team G-1, O'Regan Fall 2021 회원
YORK-O'REGAN-F21SGG1
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 568
