주요 콘텐츠로 건너뛰기
Expansion Bay Prereq
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Expansion Bay Prereq, Before you begin: 1 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Expansion Bay Prereq, Remove the touchpad spacers: 2 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the touchpad spacers: 2 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the touchpad spacers: 2 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. Expansion Bay Prereq: 3 단계, 이미지 1개 중 1개
    • Repeat the same procedure for the other touchpad spacer.
  4. Expansion Bay Prereq, Remove the touchpad: 4 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the touchpad: 4 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the touchpad: 4 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  5. Expansion Bay Prereq, Remove the keyboard: 5 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the keyboard: 5 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the keyboard: 5 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  6. Expansion Bay Prereq, Remove the numpad: 6 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the numpad: 6 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the numpad: 6 단계, 이미지 3개 중 3개
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  7. Expansion Bay Prereq, Disconnect the midframe cable: 7 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Disconnect the midframe cable: 7 단계, 이미지 2개 중 2개
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  8. Expansion Bay Prereq, Loosen the midframe screws: 8 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Loosen the midframe screws: 8 단계, 이미지 2개 중 2개
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  9. Expansion Bay Prereq, Remove the midframe: 9 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Remove the midframe: 9 단계, 이미지 2개 중 2개
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  10. Expansion Bay Prereq: 10 단계, 이미지 2개 중 1개 Expansion Bay Prereq: 10 단계, 이미지 2개 중 2개
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  11. Expansion Bay Prereq, Loosen the battery screws: 11 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Loosen the battery screws: 11 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  12. Expansion Bay Prereq, Remove the battery: 12 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the battery: 12 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the battery: 12 단계, 이미지 3개 중 3개
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  13. Expansion Bay Prereq, Lift the interposer door: 13 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Lift the interposer door: 13 단계, 이미지 2개 중 2개
    • Lift the interposer door by its black pull tab and let it rest upright.
  14. Expansion Bay Prereq, Loosen the interposer screws: 14 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Loosen the interposer screws: 14 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Loosen the interposer screws: 14 단계, 이미지 3개 중 3개
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  15. Expansion Bay Prereq, Remove the interposer: 15 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Remove the interposer: 15 단계, 이미지 2개 중 2개
    • Lift the interposer by its pull tab and remove it.
  16. Expansion Bay Prereq, Loosen the expansion bay screws: 16 단계, 이미지 2개 중 1개 Expansion Bay Prereq, Loosen the expansion bay screws: 16 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  17. Expansion Bay Prereq, Remove the Expansion Bay module: 17 단계, 이미지 3개 중 1개 Expansion Bay Prereq, Remove the Expansion Bay module: 17 단계, 이미지 3개 중 2개 Expansion Bay Prereq, Remove the Expansion Bay module: 17 단계, 이미지 3개 중 3개
    • Slide the Expansion Bay module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
결론
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,624 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,828개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 36
