필요한 것
Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
Press tab on inside of device to release silver ring.
Gently remove top (silver) ring of lens casing with your fingers.
Remove the small, black, ridged inner ring around the lens with your fingers.
Turn the hollow outer casing so that you can see inside of it.
Gently pull out main board with fingers.
Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
Twist the lens piece in clockwise and then insert black ring around the lens.
Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
Insert the silver ring. You should hear it click into place.
Hold the camera in one hand with the hollow side facing up.
Hold the USB cable in your other hand with the four small holes facing up.
Plug the USB cable into the port.
Lay the USB cord in the notch at the base of the camera bottom.
Place the bottom back onto the camera top.
Line up the base of the camera with the screw holes.
Use a Phillips-head screwdriver to twist the three screws back into place.
