주요 콘텐츠로 건너뛰기
FAO Schwarz Apex 1 Front Axle Replacement
필요한 것
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 1 단계, 이미지 1/3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 1 단계, 이미지 2/3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 1 단계, 이미지 3/3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: 2 단계, 이미지 1/1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: 3 단계, 이미지 1/2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: 3 단계, 이미지 2/2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: 4 단계, 이미지 1/1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: 5 단계, 이미지 1/1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 6 단계, 이미지 1/3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 6 단계, 이미지 2/3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 6 단계, 이미지 3/3
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: 7 단계, 이미지 1/2 FAO Schwarz Apex 1 Front Axle Replacement: 7 단계, 이미지 2/2
    • Position the axle entirely upright before lifting away from the vehicle.
결론
Carsyn Bernhardt
회원 가입일: 09/07/18
88 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 17
전체 시간: 268
