주요 콘텐츠로 건너뛰기
소개
Is your FAO Schwarz Apex 1 failing to take turns and drift correctly? This guide will show you how to replace a wheel on your Classic Racer and correct any unwanted device maneuvering caused by a faulty wheel. All this simple fix requires is a J1 screwdriver bit to remove and reinstall the screws holding the wheel on.
부품
지정된 부품이 없습니다.
  1. Position device so that the wheels are on a firm surface . Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel. Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
April Wilson
회원 가입일: 2018년 09월 07일
374 평판
안내서 3개 작성하였습니다
I have a question about this! I had one of these cars for my son and lost the remote so I ordered another one off ebay. The new one arrived damaged, with one of the rear wheels broken off. The black plastic part on the axle that the wheel screwed into was cracked. So I’m trying to figure out if there is a way to remove this black plastic part from the old car to put on the new one. Or if I can swap out the whole rear axle. I really am not too mechanically inclined, but I want my son to have his remote control car functioning again and I’m really trying to avoid purchasing a 3rd one. Thank you!
Lindsay - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 116
