주요 콘텐츠로 건너뛰기
FAO Schwarz Apex 1 Wheel Replacement
필요한 것
  1. FAO Schwarz Apex 1 Wheel Replacement, Wheel: 1 단계, 이미지 1/3 FAO Schwarz Apex 1 Wheel Replacement, Wheel: 1 단계, 이미지 2/3 FAO Schwarz Apex 1 Wheel Replacement, Wheel: 1 단계, 이미지 3/3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Wheel Replacement: 2 단계, 이미지 1/1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
April Wilson
회원 가입일: 09/07/18
374 평판
안내서 3개 작성하였습니다
댓글 한 개
I have a question about this! I had one of these cars for my son and lost the remote so I ordered another one off ebay. The new one arrived damaged, with one of the rear wheels broken off. The black plastic part on the axle that the wheel screwed into was cracked. So I’m trying to figure out if there is a way to remove this black plastic part from the old car to put on the new one. Or if I can swap out the whole rear axle. I really am not too mechanically inclined, but I want my son to have his remote control car functioning again and I’m really trying to avoid purchasing a 3rd one. Thank you!
Lindsay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 253
