이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Position device so that the wheels are on a firm surface .
Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I have a question about this! I had one of these cars for my son and lost the remote so I ordered another one off ebay. The new one arrived damaged, with one of the rear wheels broken off. The black plastic part on the axle that the wheel screwed into was cracked. So I’m trying to figure out if there is a way to remove this black plastic part from the old car to put on the new one. Or if I can swap out the whole rear axle. I really am not too mechanically inclined, but I want my son to have his remote control car functioning again and I’m really trying to avoid purchasing a 3rd one. Thank you!
