주요 콘텐츠로 건너뛰기
FLSUN QQ Stepper Driver Replacement (TMC2208)
필요한 것
    • Power Off Printer
    • Unplug Printer From Outlet
  1. FLSUN QQ Stepper Driver Replacement (TMC2208), Open Base of Printer: 2 단계, 이미지 1개 중 1개
    • Use 2.5mm Hex Driver
    • Remove 6 Screws from Base of Printer
    • Carefully remove cover.
  2. FLSUN QQ Stepper Driver Replacement (TMC2208), Remove Old Stepper Driver: 3 단계, 이미지 1개 중 1개
    • Unplug Stepper Cable
    • Gently Remove Stepper Driver
    • You can skip this step if you reverse the direction of the steppers in firmware.
    • Using small needle nose pliers gently remove the plastic clip that holds the stepper cable connector.
    • Alternate pulling from the top and bottom of the clip to avoid damage to the board.
    • Rotate the plastic clip 180º
    • Gently, but firmly, press the plastic clip back onto the board.
  3. FLSUN QQ Stepper Driver Replacement (TMC2208), Plug In the New TMC2208 Driver: 5 단계, 이미지 1개 중 1개
    • Align the pins in the correct location and position.
    • In my case the blue header on the TMC2208 aligned with the green side of the socket on the board.
    • Press gently but firmly into place.
  4. FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: 6 단계, 이미지 3개 중 1개 FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: 6 단계, 이미지 3개 중 2개 FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: 6 단계, 이미지 3개 중 3개
    • Avoid shorting out any of the pins. Do not place heat sink in contact with any of the pins.
    • Remove sticker from back of heat sink
    • Carefully press the heat sink to the back of the TMC2208
    • Remove Old Driver
    • Reverse Direction of Stepper
    • Insert TMC2208
    • Add Heatsink
    • Plug Stepper Back In
결론
Re-assemble your printer and enjoy near silent (fans make some noise) printing!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Daniel Green
회원 가입일: 02/08/15
1,161 평판
안내서 6개를 작성함
8가이드 댓글
How about Vref?
wmenant - 답글
I haven't needed to mess with it.
Daniel Green -
Hi, thanks for a great tutorial!
Does the firmware of the QQ-S need to be updated/replaced as well, or will these drivers run with stock FW?
Thanks again!
RJ T - 답글
You can either, flip the orientation of the plug on the board, or modify config values in the firmware config file and re-flash the firmware. I chose to flip the plug so I would need to mess with flashing firmware.
Daniel Green - 답글
Do you need to reverse the plug for a 2209? Difference between 2208 and 2209 for my QQS Pro?
Alex Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 6,121
