주요 콘텐츠로 건너뛰기
Factory Reset, Fix Android Problems with Sony PC Companion
동영상 개요
  1. Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 1 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 1 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 1 단계, 이미지 3/3
  2. Factory Reset, Fix Android Problems  with Sony PC Companion: 2 단계, 이미지 1/2 Factory Reset, Fix Android Problems  with Sony PC Companion: 2 단계, 이미지 2/2
    • Install Sony PC Companion in your PC.
  3. Factory Reset, Fix Android Problems  with Sony PC Companion: 3 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 3 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 3 단계, 이미지 3/3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
    It will not let me does this because I haven’t got the password for my phone so when I go onto the pc companion it says that because my phone is locked I can’t do it I just need to be able to unlock my Xperia M2 help!!
    Taya louise - 답글
  4. Factory Reset, Fix Android Problems  with Sony PC Companion: 4 단계, 이미지 1/2 Factory Reset, Fix Android Problems  with Sony PC Companion: 4 단계, 이미지 2/2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  5. Factory Reset, Fix Android Problems  with Sony PC Companion: 5 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 5 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 5 단계, 이미지 3/3
    • Select the model of your phone.
    • You should not confuse the model.
  6. Factory Reset, Fix Android Problems  with Sony PC Companion: 6 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 6 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 6 단계, 이미지 3/3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  7. Factory Reset, Fix Android Problems  with Sony PC Companion: 7 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 7 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 7 단계, 이미지 3/3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • '''Android WinUSB drivers'''
  8. Factory Reset, Fix Android Problems  with Sony PC Companion: 8 단계, 이미지 1/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 8 단계, 이미지 2/3 Factory Reset, Fix Android Problems  with Sony PC Companion: 8 단계, 이미지 3/3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
    After repair software does not success and may the device contains modified software that cannot be repaired error code Ue getphoneinforooteddevice UE-2003
    rabindrashrestha98 - 답글
결론
다른 113명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 26개
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
Godstime Osarobo - 답글
my xperia ( LT22i ) is not listed
abdul azeem - 답글
there is an error every time i try to use pc companion
error code: uegetphoneinfofailure
leo leo - 답글
there are an error
I can't download the upgrade on my phone
arnold - 답글
can any one help me ??????????
arnold - 답글
handset is stuck in a boot up mode / optimising of application - screen and power on/off have no effect - keeps repeating this process and getting hotter?
since the new android marshmellow tried to download - ???
PC Companion does not acknowledge the connection to the handset - requests to wait until restart complete and/or PCC detects handset - neither happen as stuck in loop - cables are all ok
HELP
Xperia Z
Kevin - 답글
I can't get the three options that come after clicking on the "Support Zone " option, I need help!!!!
thom4jesus - 답글
If you use Windows 10 you need to disable the driver signature enforcement to install the android usb drivers from the Sony homepage. For that you need to do an restart with special setup of Windows 10.
Claes - 답글
Sony Xperia Z C0682 is not in the model list. What should I do?
Warren Razon - 답글
how long does it takes (hrs) on software repair?? any guys.. ^^', tnx alot
karr pasaporte - 답글
I can't download the PC Companion!!!!!!!!!!!!!!!!
honeylight18 - 답글
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 3hrs. Can I do a factory reset or could my battery die during the process?
I Also did a battery health test and it said the battery is good
Clive Donk - 답글
What to do if the program says you have to unlock the phone, but you dont remember the passcode...?
Thomas Bakke - 답글
same man, what you do?
totouron24 -
How to recover my sony xperia d2005 after installing software update disconnected? I can open my phone but only dead android can see.
rafael jr matulac Jaen - 답글
mon téléphone portable Sony refuse de s'allume je ne sais pas si il est programme ou pas . je ve que vous m'aider. model D2005.
jean - 답글
Hi.
My Xperia e3 dual device is under continue boot loop. Can it be rectified by master format.. Also is there any possibility for data recovery if I don't have a back up done
vipul - 답글
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
Sujith Nettur - 답글
I'm having issues with my Xperia z1 battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
Sujith Nettur - 답글
The current version of Xperia Companion (v. 1.5.3.0) had 2 errors on my PC (W7 64 SP1):
1) Setup with .DLL problem: I fixed the problem by installing an update for Windows - Windows KB 2533623 (Windows6.1-KB2533623-x64.msu) -, easily found on the Microsot website. After the update, the Companion was installed normally;
2) Several failures when trying to upgrade or repair my smartphone, such as "unexpected error", "login failure", "download failure", etc .: I corrected the problem by uninstalling the "Sony Mobile Update Engine", by Control panel. This software is installed automatically by the Xperia Companion setup. After uninstalling this software, Xperia Companion will no longer display any errors (and will install the Sony Mobile Update Engine again during the operation of your device, this time not causing the error!).
At least for me everything worked this way and, since I did not see this unusual solution on another site, I decided to post it, in case it would be useful to someone else.
Good luck!
donizildodasilva - 답글
please whats the file to format my xperia its too slow and keep reloading over and over again
ayola robinson - 답글
dear sir/ madam,
on my system, the Sony pc companion is not installing please help me.
Arwinder Singh Mann - 답글
hi how are u sir my phone xperia vl is not open password and no reset how can i solve it plz tell me soultion
syed adnan - 답글
Amazing this is so help full thank you so much SP flash
decorationideas3 - 답글
??? if i have Malware on my phone can using this program infect my lap top
Tanya Kintz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 41
30일 전: 166
전체 시간: 231,404
