주요 콘텐츠로 건너뛰기
Fahrenheit FHT 125PRMR Power Cord Replacement
필요한 것
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: 2 단계, 이미지 1/1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: 3 단계, 이미지 1/2 Fahrenheit FHT 125PRMR Power Cord Replacement: 3 단계, 이미지 2/2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: 4 단계, 이미지 1/2 Fahrenheit FHT 125PRMR Power Cord Replacement: 4 단계, 이미지 2/2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: 5 단계, 이미지 1/1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joshua Potts
회원 가입일: 09/29/16
265 평판
안내서 1개 작성함
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G2
4 회원들
안내서 4개 작성하였습니다
댓글 3개
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - 답글
Where do you buy the power cord?
Dominique - 답글
probably available at electronic store
john john - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 2,451
