주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fairphone 1 Midframe Replacement
필요한 것
  1. Fairphone 1 Midframe Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
    댓글 쓰기
  2. Fairphone 1 Midframe Replacement: 2 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement: 2 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the back cover down and remove it from the phone.
    댓글 쓰기
  3. Fairphone 1 Midframe Replacement, Battery: 3 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement, Battery: 3 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
    댓글 쓰기
  4. Fairphone 1 Midframe Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from your Fairphone.
    댓글 쓰기
  5. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 3개
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
    댓글 쓰기
  6. Fairphone 1 Midframe Replacement: 6 단계, 이미지 2개 중 1개 Fairphone 1 Midframe Replacement: 6 단계, 이미지 2개 중 2개
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
    댓글 쓰기
  7. Fairphone 1 Midframe Replacement, Midframe Assembly: 7 단계, 이미지 1개 중 1개
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
    댓글 쓰기
  8. Fairphone 1 Midframe Replacement: 8 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement: 8 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement: 8 단계, 이미지 3개 중 3개
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
    댓글 쓰기
  9. Fairphone 1 Midframe Replacement: 9 단계, 이미지 2개 중 1개 Fairphone 1 Midframe Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully round the corner, separating the midframe from the display assembly.
    댓글 쓰기
  10. Fairphone 1 Midframe Replacement: 10 단계, 이미지 1개 중 1개
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
    댓글 쓰기
  11. Fairphone 1 Midframe Replacement: 11 단계, 이미지 3개 중 1개 Fairphone 1 Midframe Replacement: 11 단계, 이미지 3개 중 2개 Fairphone 1 Midframe Replacement: 11 단계, 이미지 3개 중 3개
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
    댓글 쓰기
  12. Fairphone 1 Midframe Replacement: 12 단계, 이미지 1개 중 1개
    • Separate any remaining clips and remove the midframe from the phone.
    댓글 쓰기
  13. Fairphone 1 Midframe Replacement, Midframe: 13 단계, 이미지 2개 중 1개 Fairphone 1 Midframe Replacement, Midframe: 13 단계, 이미지 2개 중 2개
    • The speakerphone speaker is held to the midframe with some mild adhesive.
    • Use the tip of a spudger to pry the speaker off of the midframe.
    댓글 쓰기
  14. Fairphone 1 Midframe Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the speaker from the midframe.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,373 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 25,857개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 49
전체 시간: 11,386
