주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fairphone 1 RF Cable Replacement
필요한 것
  1. Fairphone 1 RF Cable Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
    댓글 쓰기
  2. Fairphone 1 RF Cable Replacement: 2 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement: 2 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the back cover down and remove it from the phone.
    댓글 쓰기
  3. Fairphone 1 RF Cable Replacement, Battery: 3 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, Battery: 3 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
    댓글 쓰기
  4. Fairphone 1 RF Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from your Fairphone.
    댓글 쓰기
  5. Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: 5 단계, 이미지 3개 중 3개
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
    댓글 쓰기
  6. Fairphone 1 RF Cable Replacement: 6 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 6 단계, 이미지 2개 중 2개
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
    댓글 쓰기
  7. Fairphone 1 RF Cable Replacement, Midframe Assembly: 7 단계, 이미지 1개 중 1개
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
    댓글 쓰기
  8. Fairphone 1 RF Cable Replacement: 8 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement: 8 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement: 8 단계, 이미지 3개 중 3개
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
    댓글 쓰기
  9. Fairphone 1 RF Cable Replacement: 9 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully round the corner, separating the midframe from the display assembly.
    댓글 쓰기
  10. Fairphone 1 RF Cable Replacement: 10 단계, 이미지 1개 중 1개
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
    댓글 쓰기
  11. Fairphone 1 RF Cable Replacement: 11 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement: 11 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement: 11 단계, 이미지 3개 중 3개
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
    댓글 쓰기
  12. Fairphone 1 RF Cable Replacement: 12 단계, 이미지 1개 중 1개
    • Separate any remaining clips and remove the midframe from the phone.
    댓글 쓰기
  13. Fairphone 1 RF Cable Replacement, Motherboard Assembly: 13 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, Motherboard Assembly: 13 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, Motherboard Assembly: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
    댓글 쓰기
  14. Fairphone 1 RF Cable Replacement: 14 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
    댓글 쓰기
  15. Fairphone 1 RF Cable Replacement: 15 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 15 단계, 이미지 2개 중 2개
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
    댓글 쓰기
  16. Fairphone 1 RF Cable Replacement: 16 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement: 16 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement: 16 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
    댓글 쓰기
  17. Fairphone 1 RF Cable Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
    댓글 쓰기
  18. Fairphone 1 RF Cable Replacement: 18 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 18 단계, 이미지 2개 중 2개
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
    댓글 쓰기
  19. Fairphone 1 RF Cable Replacement: 19 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 19 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
    댓글 쓰기
  20. Fairphone 1 RF Cable Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the motherboard from the display assembly.
    댓글 쓰기
  21. Fairphone 1 RF Cable Replacement, Wi-Fi Antenna Daughterboard: 21 단계, 이미지 1개 중 1개
    • Be careful to pry on the connector, not the socket.
    댓글 쓰기
  22. Fairphone 1 RF Cable Replacement: 22 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement: 22 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement: 22 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
    댓글 쓰기
  23. Fairphone 1 RF Cable Replacement: 23 단계, 이미지 1개 중 1개
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Two 2.5 mm Phillips #000 screws
    • One 1.6 mm Phillips #000 screw
    댓글 쓰기
  24. Fairphone 1 RF Cable Replacement: 24 단계, 이미지 2개 중 1개 Fairphone 1 RF Cable Replacement: 24 단계, 이미지 2개 중 2개
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
    댓글 쓰기
  25. Fairphone 1 RF Cable Replacement, Earpiece Speaker: 25 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, Earpiece Speaker: 25 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, Earpiece Speaker: 25 단계, 이미지 3개 중 3개
    • The earpiece speaker is held to the back of the display assembly with some mild adhesive.
    • Use the tip of a spudger to gently pry the speaker up from the display assembly.
    • Remove the speaker.
    댓글 쓰기
  26. Fairphone 1 RF Cable Replacement, RF Cable: 26 단계, 이미지 3개 중 1개 Fairphone 1 RF Cable Replacement, RF Cable: 26 단계, 이미지 3개 중 2개 Fairphone 1 RF Cable Replacement, RF Cable: 26 단계, 이미지 3개 중 3개
    • Remove the antenna interconnect cable from the display assembly.
    • The three sections of the cable with exposed metal fit into the grounding clips on the side of the display assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
Jasper Fleischhauer
회원 가입일: 10/20/14
37,006 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 64
전체 시간: 3,874
