소개
Re-enable hands-free speakerphone calls by replacing your broken Fairphone loudspeaker.
부품
지정된 부품이 없습니다.
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
다른 2명이 해당 안내서를 완성하였습니다.
