주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fairphone 4 Screen Replacement
필요한 것
  1. Fairphone 4 Screen Replacement, Pry the back cover up: 1 단계, 이미지 2개 중 1개 Fairphone 4 Screen Replacement, Pry the back cover up: 1 단계, 이미지 2개 중 2개
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Screen Replacement: 2 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement: 2 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Screen Replacement: 3 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement: 3 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Screen Replacement: 4 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement: 4 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Screen Replacement, Lever up the Battery: 5 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement, Lever up the Battery: 5 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement, Lever up the Battery: 5 단계, 이미지 3개 중 3개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Screen Replacement, Unscrew the display: 6 단계, 이미지 1개 중 1개
    • Remove the eight 4.8 mm-long Phillips screws.
  7. Fairphone 4 Screen Replacement, Create a gap: 7 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement, Create a gap: 7 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement, Create a gap: 7 단계, 이미지 3개 중 3개
    • Flip the phone over so the screen faces up
    • Insert an opening pick between the screen and the frame.
  8. Fairphone 4 Screen Replacement, Slide along the edge: 8 단계, 이미지 2개 중 1개 Fairphone 4 Screen Replacement, Slide along the edge: 8 단계, 이미지 2개 중 2개
    • Slide the opening pick along the edge to the top right corner.
  9. Fairphone 4 Screen Replacement: 9 단계, 이미지 2개 중 1개 Fairphone 4 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Continue to slide the opening pick along the top of the phone.
  10. Fairphone 4 Screen Replacement: 10 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement: 10 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick along the left side to the bottom left corner.
  11. Fairphone 4 Screen Replacement, Flip the screen over: 11 단계, 이미지 3개 중 1개 Fairphone 4 Screen Replacement, Flip the screen over: 11 단계, 이미지 3개 중 2개 Fairphone 4 Screen Replacement, Flip the screen over: 11 단계, 이미지 3개 중 3개
    • Do not remove the screen yet. It's still connected to the phone with a connection cable.
    • Grab the screen and lift it straight up just enough to clear its pegs from the frame.
    • Rotate the display carefully clock-wise and flip it over to get access to the connector.
    • Place the display on the device with the screen facing downwards.
  12. Fairphone 4 Screen Replacement, Disconnect the cable: 12 단계, 이미지 2개 중 1개 Fairphone 4 Screen Replacement, Disconnect the cable: 12 단계, 이미지 2개 중 2개
    • Use an opening pick to pry up and disconnect the display connection cable.
    • Remove the screen.
    • Compare your new replacement screen to the original part—you may need to remove a front camera dust cover before you install it.
결론
다른 27명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
25,098 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,583개를 작성함
16가이드 댓글
20-40 Minutes? ... more like 10 ... and I wasn't even pushing it
Patrick Küster - 답글 공유
Thanks for your comment! The time estimate was set a little too high, you're right. I've adjusted it!
Manuel Haeussermann - 공유
10 minutes, like you. Honnestly I'm so happy to be apple to fix it by my own. Thanks to the Fairphone's engineers. I would never buy another phone yet. And I hope I could keep this one 10 more years!
Cédric Chauveau - 공유
Vielen Dank für die präzise Anleitung. Auf alle heiklen Punkte wurde hingewiesen. Habe es locker geschafft und war danach ganz stolz!
Johanna - 답글 공유
I can confirm that you need a #0 screwdriver, not a #00, as has been changed in the latest unchecked version.
Jonathan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 187
지난 30일: 651
전체 시간: 25,530
