주요 콘텐츠로 건너뛰기
Fairphone Fairbuds Outer Shell Replacement
필요한 것
  1. Fairphone Fairbuds Outer Shell Replacement, Remove the outer shell screw: 1 단계, 이미지 1/2 Fairphone Fairbuds Outer Shell Replacement, Remove the outer shell screw: 1 단계, 이미지 2/2
    • Flip your charging case upside down.
    • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
  2. Fairphone Fairbuds Outer Shell Replacement, Remove the charging core: 2 단계, 이미지 1/2 Fairphone Fairbuds Outer Shell Replacement, Remove the charging core: 2 단계, 이미지 2/2
    • Flip up the bottom of the outer shell.
  3. Fairphone Fairbuds Outer Shell Replacement: 3 단계, 이미지 1/3 Fairphone Fairbuds Outer Shell Replacement: 3 단계, 이미지 2/3 Fairphone Fairbuds Outer Shell Replacement: 3 단계, 이미지 3/3
    • Lift the charging core out of the outer shell and remove it.
    • You're now left with the outer shell for replacement.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
129,007 평판
안내서 600개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,982개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 24
전체 시간: 43
