주요 콘텐츠로 건너뛰기
Fan Coil Filter Replacement
필요한 것
  1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: 1 단계, 이미지 1개 중 1개
    • Clean the fan coil grilles using a paper towel and water.
    • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
  2. Fan Coil Filter Replacement: 2 단계, 이미지 1개 중 1개
    • Close off each adjustable damper.
    • This will ensure that the register grille does not get in the way later on during the filter removal.
  3. Fan Coil Filter Replacement: 3 단계, 이미지 2개 중 1개 Fan Coil Filter Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screws from fan coil using a Phillips #1 screwdriver.
    • Open up the fan coil.
  4. Fan Coil Filter Replacement: 4 단계, 이미지 1개 중 1개
    • Use your hands to remove the filter from the fan coil.
  5. Fan Coil Filter Replacement: 5 단계, 이미지 2개 중 1개 Fan Coil Filter Replacement: 5 단계, 이미지 2개 중 2개
    • Replace the fan coil filter.
    • Make sure to close the fan coil door after the filter replacement is completed.
  6. Fan Coil Filter Replacement: 6 단계, 이미지 2개 중 1개 Fan Coil Filter Replacement: 6 단계, 이미지 2개 중 2개
    • Screw in closed the fan coil door.
    • Open up each of the adjustable dampers for better air flow.
결론
Following these steps, you will be able to replace the filter in your fan coil system.
작성자
1다른 기여자 명과 함께
Abukar Ahmed
회원 가입일: 09/20/20
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 27
전체 시간: 1,021
