주요 콘텐츠로 건너뛰기
Fan Replacement
필요한 것
  1. Fan Replacement, Fan/Heat Sink: 1 단계, 이미지 1/1
    • Remove all the screws that hold the plastic bottom cover on. There are some more screws that cant be seen in the photo.
  2. Fan Replacement: 2 단계, 이미지 1/1
    • Once screws are removed, remove the back cover.
  3. Fan Replacement: 3 단계, 이미지 1/1
    • Encased in red is the area where we are working on
  4. Fan Replacement: 4 단계, 이미지 1/2 Fan Replacement: 4 단계, 이미지 2/2
    • Locate the two strips of cables projecting from the fan to the white holders circled in red.
    • Using your hand carefully remove the two strips of cables from the white sockets. Preferably grabbing the strip by the head(the white section where the cables are engulfed). If unable to gingerly pull on the cables.
    • Make care to not rip the connectors and the cables
  5. Fan Replacement: 5 단계, 이미지 1/1
    • Unscrew the four screws surrounding the heat sink.
  6. Fan Replacement: 6 단계, 이미지 1/1
    • You are now clear for liftoff. The fan may fly freely.
    • Now is a prime time to reapply thermal paste if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Martinez
회원 가입일: 02/14/17
637 평판
안내서 6개 작성하였습니다
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 520
