이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First, make sure your disc drive is empty.
(PS3 Fat Only) Turn your PS3 from standby to off by flipping the switch on the back of the system, hold down the eject button and then flip the switch back on.
(PS3 Slim Only) Unplug the power cable from the system, hold down the eject button and then plug the cable back in.
Your system will turn on and within a matter of seconds you will hear the fan inside the PS3 begin to spin at a much higher rate than normal. It should run for about 15-20 seconds. In this demonstration the fans run for 16.96 seconds.
When complete, the power (red) light will blink (PS3 Fat) or be completely off (PS3 Slim)
(PS3 Fat Only) Hit the switch on the back of your system to off and back to standby. You're done!
(PS3 Slim) Unplug your power cord and then plug it back in. You're done!
다른 50명이 해당 안내서를 완성하였습니다.
댓글 31개
Doesn't work on superslim eject button just releases the tray not electrical
taipancorbett,
Thanks for informing me. Honestly, I've seen this done with the original and personally preformed it on the slim and assumed that it worked with the super slim as well. Looks like I made an ass out of myself. I'll make the corrections to the guide.
That said, it stands to reason that it should have a way to detect an open lid. Has that been tried? Plugging it in with the lid open?
How can we do that on the super slim model? Or what the other option to do this self cleaning?
I'm afraid I don't know how to preform this test on the super slim. I would search youtube/web searches.
