주요 콘텐츠로 건너뛰기
소개
This fast fix is to fix the buttons on a 2006 Honda Cr-V key fob. It is a very simple and easy fix. You will only need one tool and the replacement part.
도구
부품
  1. You will need to take the key off the ring.
    • You will need to take the key off the ring.
  2. The second step is to take out the little screw on the back side of the key.
    • The second step is to take out the little screw on the back side of the key.
  3. Unclip the back part of your key.
    • Unclip the back part of your key.
    • This part is super fragile.
  4. You will push the buttons from the front side to have the middle piece fall out.
    • You will push the buttons from the front side to have the middle piece fall out.
  5. Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily. Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
    • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
  6. Then push the buttons from the front side to push out a rubber insert. Then push the buttons from the front side to push out a rubber insert.
    • Then push the buttons from the front side to push out a rubber insert.
  7. Then peel out the mother chip and replace your rubber insert.
    • Then peel out the mother chip and replace your rubber insert.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Greer
회원 가입일: 2019년 04월 11일
169 평판
안내서 1개 작성함
댓글 2개
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Me Me - 답글
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 436
