소개
Overtime, tub drainers become old and need to be replaced. The purpose of this guide is to provide an easy, safe, and affordable way to replace your own bathtub drainer without calling someone out to come and fix it.
What do you need?
I went to my local Home Depot store and purchased the Danco EZ Drain Cover. The package included: the EZ Drain Cover and 2 gaskets
Step 2.
The gaskets come in two sizes, large and small. Determine which is the correct size. To do this, position the gasket into the groove of the stopper with the flange side in the upward position. Insert the stopper with the gasket in the drain. I tried the smaller one first and it was loose; then I tried the larger size & it fitted the drain perfectly
다른 한 분이 해당 안내서를 완성하였습니다.
