주요 콘텐츠로 건너뛰기
Fast Fix Dryer Vent Hose Replacement
필요한 것
  1. Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 1 단계, 이미지 1/3 Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 1 단계, 이미지 2/3 Fast Fix Dryer Vent Hose Replacement, Dryer Vent Hose: 1 단계, 이미지 3/3
    • The first step is to locate the dryer vent hose where it attaches to the dryer. You will then detach the dryer hose from the exhaust port, and clean any lint that has gathered there.
  2. Fast Fix Dryer Vent Hose Replacement: 2 단계, 이미지 1/3 Fast Fix Dryer Vent Hose Replacement: 2 단계, 이미지 2/3 Fast Fix Dryer Vent Hose Replacement: 2 단계, 이미지 3/3
    • The next step is to locate the dryer vent, which should be on the outside of the house. You will detach the dryer vent by unscrewing the four screws holding it to the house. Then you will dispose of the old dryer hose/tube.
  3. Fast Fix Dryer Vent Hose Replacement: 3 단계, 이미지 1/2 Fast Fix Dryer Vent Hose Replacement: 3 단계, 이미지 2/2
    • The third step is to attach the new dryer vent hose. You will slip it onto the dryer's exhaust port.
  4. Fast Fix Dryer Vent Hose Replacement: 4 단계, 이미지 1/1
    • The fourth step is to secure the new dryer hose with a dryer tube clamp.
  5. Fast Fix Dryer Vent Hose Replacement: 5 단계, 이미지 1/3 Fast Fix Dryer Vent Hose Replacement: 5 단계, 이미지 2/3 Fast Fix Dryer Vent Hose Replacement: 5 단계, 이미지 3/3
    • The fifth step is to make sure your new dryer hose is strung through to the outside dryer vent.
  6. Fast Fix Dryer Vent Hose Replacement: 6 단계, 이미지 1/2 Fast Fix Dryer Vent Hose Replacement: 6 단계, 이미지 2/2
    • The sixth step is to slip on the other dryer tube clamp in order to secure it to the outdoor dryer vent.
  7. Fast Fix Dryer Vent Hose Replacement: 7 단계, 이미지 1/2 Fast Fix Dryer Vent Hose Replacement: 7 단계, 이미지 2/2
    • The last step is to rescuer the clean dryer vent to the outside of the house using screws.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rachel Chapman
회원 가입일: 06/07/23
181 평판
안내서 1개 작성함
University of Memphis, Team 1-5, Lane Summer 2023 University of Memphis, Team 1-5, Lane Summer 2023 회원
UM-LANE-SU23S1G5
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 166
