주요 콘텐츠로 건너뛰기
Fast Fix FOB Battery Replacement
필요한 것
  1. Fast Fix FOB Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Purchase two CR2016 batteries.
    • You can find these at your local drugstore or hardware store.
  2. Fast Fix FOB Battery Replacement: 2 단계, 이미지 1/2 Fast Fix FOB Battery Replacement: 2 단계, 이미지 2/2
    • Use a small and thin object, like a penny or other coin, to pry open the FOB. It will separate into two pieces.
  3. Fast Fix FOB Battery Replacement: 3 단계, 이미지 1/1
    • Identify which part of the FOB holds the battery. You should be able to clearly see the circular batteries in one half.
    • You should be able to clearly see the circular batteries in one half. You will not the need the other part of the FOB until the end.
  4. Fast Fix FOB Battery Replacement: 4 단계, 이미지 1/2 Fast Fix FOB Battery Replacement: 4 단계, 이미지 2/2
    • Remove both batteries from the FOB by releasing them from the prongs.
  5. Fast Fix FOB Battery Replacement: 5 단계, 이미지 1/2 Fast Fix FOB Battery Replacement: 5 단계, 이미지 2/2
    • Insert the new CR2016 batteries with the positive side facing down, and make sure the batteries are secure under the prongs.
  6. Fast Fix FOB Battery Replacement: 6 단계, 이미지 1/3 Fast Fix FOB Battery Replacement: 6 단계, 이미지 2/3 Fast Fix FOB Battery Replacement: 6 단계, 이미지 3/3
    • Put the FOB back together.
    • You should hear a click that secures the two pieces in place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
jtorman@udel.edu
회원 가입일: 02/20/18
196 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 297
