주요 콘텐츠로 건너뛰기
Fan Blade Arm Replacement
필요한 것
  1. Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 1/3 Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 2/3 Fan Blade Arm Replacement, Fan Blade Arm: 1 단계, 이미지 3/3
    • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
  2. Fan Blade Arm Replacement: 2 단계, 이미지 1/2 Fan Blade Arm Replacement: 2 단계, 이미지 2/2
    • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
  3. Fan Blade Arm Replacement: 3 단계, 이미지 1/3 Fan Blade Arm Replacement: 3 단계, 이미지 2/3 Fan Blade Arm Replacement: 3 단계, 이미지 3/3
    • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
  4. Fan Blade Arm Replacement: 4 단계, 이미지 1/2 Fan Blade Arm Replacement: 4 단계, 이미지 2/2
    • Disconnect single pin connectors to finish removing light fixture from fan.
  5. Fan Blade Arm Replacement: 5 단계, 이미지 1/2 Fan Blade Arm Replacement: 5 단계, 이미지 2/2
    • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
  6. Fan Blade Arm Replacement: 6 단계, 이미지 1/3 Fan Blade Arm Replacement: 6 단계, 이미지 2/3 Fan Blade Arm Replacement: 6 단계, 이미지 3/3
    • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
  7. Fan Blade Arm Replacement: 7 단계, 이미지 1/3 Fan Blade Arm Replacement: 7 단계, 이미지 2/3 Fan Blade Arm Replacement: 7 단계, 이미지 3/3
    • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
    You forgot to mention where you magically bought that replacement piece for that particular ceiling fan!!!
    Brandy Broussard - 답글
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ricardo Ledesma Hernandez
회원 가입일: 10/29/19
145 평판
안내서 1개 작성함
University of Memphis, Team S1-G10, Willis Fall 2019 University of Memphis, Team S1-G10, Willis Fall 2019 회원
UM-WILLIS-F19S1G10
3 회원들
안내서 1개 작성하였습니다
댓글 4개
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - 답글
I am as well and harbor breeze and Lowe's are absolutely no help!
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - 답글
Where can I find an exact replacement.
Darrell Resler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 89
30일 전: 130
전체 시간: 7,365
