이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
Disconnect single pin connectors to finish removing light fixture from fan.
Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
I am as well and harbor breeze and Lowe's are absolutely no help!
