주요 콘텐츠로 건너뛰기
Fast Fix Fluval Spec V Impeller Replacement
필요한 것
  1. Fast Fix Fluval Spec V Impeller Replacement, Fluval Spec V Impeller: 1 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement, Fluval Spec V Impeller: 1 단계, 이미지 2개 중 2개
    • Unplug Aquarium: Firmly but carefully unplug it.
    • Never try to perform any maintenance or repair tasks on an aquarium or any other electrical appliance while it is still connected to a power source.
  2. Fast Fix Fluval Spec V Impeller Replacement: 2 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 2 단계, 이미지 2개 중 2개
    • Remove Light: Carefully lift light from its mount, ensuring not to pull on any wires.
    • If the light is connected to a different power source, disconnect it first before removal.
    • Remove Lid Securely grasp edge of the aquarium lid and lift up to remove.
  3. Fast Fix Fluval Spec V Impeller Replacement: 3 단계, 이미지 3개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 3 단계, 이미지 3개 중 2개 Fast Fix Fluval Spec V Impeller Replacement: 3 단계, 이미지 3개 중 3개
    • Insert Pry Tool: Take a small, flat-head screwdriver or pry tool and carefully insert it between the nozzle and the filter tube.
    • Pry Off Nozzle: Carefully apply some leverage to pry nozzle away from the filter tube. It should gradually detach.
    • Make sure to apply force evenly and gently to avoid breaking the nozzle.
    • Pull Out Filter Tube: Grasp the filter tube firmly and pull it out from the divider.
    • Pull straight sideways for easy removal, this will prevent damaging the tube or the divider.
    • If the tube is firmly stuck, try gently wiggling it as you pull.
  4. Fast Fix Fluval Spec V Impeller Replacement: 4 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 4 단계, 이미지 2개 중 2개
    • Caution: To protect Neocaridina shrimps, nano fish, and other small aquatic creatures in your aquarium, an extra precautionary step is necessary due to the potential danger posed by the outlet leading into the filtration compartment, which could cause them to get stuck behind the divider.
    • Cover Outlet (Optional): Carefully insert a suitable filter medium into the outlet.
    • This could be a piece of sponge, mesh, or any other aquarium-safe material that allows water flow while preventing the shrimps or fish from entering the filtration compartment. Be sure to securely place the filter medium so that it doesn't shift or come loose, potentially leaving the outlet unprotected.
  5. Fast Fix Fluval Spec V Impeller Replacement: 5 단계, 이미지 3개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 5 단계, 이미지 3개 중 2개 Fast Fix Fluval Spec V Impeller Replacement: 5 단계, 이미지 3개 중 3개
    • Pull Up on Output Tube: Firmly grasp the output tube and pull straight up. The pump should follow along, detaching from the bottom of the aquarium.
    • If you're having trouble removing the pump it may be due to the suction cups at the bottom of the pump securely holding it in place. In this case, try pulling up in a circular pattern. This action can help dislodge the suction cups, making it easier to lift the pump out.
    • Drain Excess Water: Hold pump over the tank for a moment to allow any excess water to drain out of the pump.
    • This will prevent water from spilling and making a mess as you work on the pump.
  6. Fast Fix Fluval Spec V Impeller Replacement: 6 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 6 단계, 이미지 2개 중 2개
    • Insert Pry Tool: Take your small pry tool and carefully insert it anywhere under the edge of the pump cover.
    • Pry Off Cover: Gently pry it off by twisting the tool.
    • Twisting the pry tool will give you a smoother, more controlled prying action and minimize the risk of the cover suddenly popping off or flying away.
  7. Fast Fix Fluval Spec V Impeller Replacement: 7 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 7 단계, 이미지 2개 중 2개
    • Insert Pry Tool: Carefully insert your pry tool anywhere under the edge of this cover.
    • Pry Off Cover: Gently pry it off.
    • Be sure to handle with care to prevent any damage to the impeller assembly underneath.
  8. Fast Fix Fluval Spec V Impeller Replacement: 8 단계, 이미지 2개 중 1개 Fast Fix Fluval Spec V Impeller Replacement: 8 단계, 이미지 2개 중 2개
    • Grasp Impeller: Get a firm but gentle grip on the impeller.
    • The impeller is inset, making it difficult to grasp by hand. In this case, a pair of needle-nose pliers will come in handy.
    • Pull Out Impeller: Slowly and carefully pull it straight out.
    • Do not to twist or yank the impeller to prevent damage to it or the pump assembly.
  9. Fast Fix Fluval Spec V Impeller Replacement: 9 단계, 이미지 1개 중 1개
    • Install New Impeller: Take your new impeller and carefully align the slot with the pin in the impeller housing. Gently slide the new impeller on to the pin, ensuring that it's oriented correctly.
    • The impeller is magnetic, so it will naturally adhere to the motor assembly and does not require any additional securing. Once the impeller is in place, it should spin freely when nudged. This will confirm that it has been installed correctly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ian Morrison
회원 가입일: 07/01/23
223 평판
안내서 1개를 작성함
1가이드 댓글
I’ve been looking everywhere for this info. Thank you!
Shauna - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 43
전체 시간: 1,032
