소개
With this step by step repair guide, you will be able to replace a fog light for a 2005 Jeep Liberty.
필요한 것
Open the hood to access the radiator grill tabs.
Pull up on the first tab and repeat for the remaining four tabs.
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
Thank was easy
