소개
This guide will show you how to replace a worn or broken clutch on the Kenmore Model 110 washing machine. If the device timer shows the cycle has completed but never drained the water or you find that the agitator is not spinning, it could mean the clutch is bad and needs to be replaced.
필요한 것
Unplug the washing machine.
Turn both the hot and cold water supply lines off.
Push tab and remove the connector that is next to the water level control on the inside of the control panel.
Pull the connector from the door safety switch located on the main body of the washing machine top.
Disconnect the green wire ground point inside the control panel with the ratchet and a 1/4 inch socket.
Separate the motor from the transmission.
Be sure to check the rubber motor coupling while it is apart. The motor and the transmission will have a plastic piece with three prongs that fit into the rubber coupling. Check to make sure plastic prongs have not broken and the rubber coupling is not cracked.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Nice tutorial! Thank you!
jdickes427 - 답글
My Kenmore washer is as same as this one, but now the agitator works, but it does not spin. So far I reached step 14, did not find anything wrong, which parts could be the problem? Clutch? Thanks
Harry Song - 답글
