주요 콘텐츠로 건너뛰기
Lamp Pull Chain Replacement
필요한 것
  1. Lamp Pull Chain Replacement, Lamp Pull Chain: 1 단계, 이미지 1/1
    • Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
  2. Lamp Pull Chain Replacement: 2 단계, 이미지 1/2 Lamp Pull Chain Replacement: 2 단계, 이미지 2/2
    • Remove the light bulb from the lamp.
  3. Lamp Pull Chain Replacement: 3 단계, 이미지 1/2 Lamp Pull Chain Replacement: 3 단계, 이미지 2/2
    • Unscrew the lamp shade from the base by turning it counter-clockwise.
  4. Lamp Pull Chain Replacement: 4 단계, 이미지 1/1
    • Gently pull the socket from the base to expose the broken chain section.
  5. Lamp Pull Chain Replacement: 5 단계, 이미지 1/2 Lamp Pull Chain Replacement: 5 단계, 이미지 2/2
    • Attach the chain connector to the extra chain.
  6. Lamp Pull Chain Replacement: 6 단계, 이미지 1/2 Lamp Pull Chain Replacement: 6 단계, 이미지 2/2
    • Connect the chain with the chain connector to the broken chain on the lamp base.
  7. Lamp Pull Chain Replacement: 7 단계, 이미지 1/3 Lamp Pull Chain Replacement: 7 단계, 이미지 2/3 Lamp Pull Chain Replacement: 7 단계, 이미지 3/3
    • Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp.
    • The chain will go down through this hole.
  8. Lamp Pull Chain Replacement: 8 단계, 이미지 1/1
    • Gently push the socket back into place.
  9. Lamp Pull Chain Replacement: 9 단계, 이미지 1/2 Lamp Pull Chain Replacement: 9 단계, 이미지 2/2
    • Screw the lamp shade back onto the base of the lamp by turning it clockwise.
  10. Lamp Pull Chain Replacement: 10 단계, 이미지 1/1
    • Replace the light bulb into the lamp socket.
  11. Lamp Pull Chain Replacement: 11 단계, 이미지 1/2 Lamp Pull Chain Replacement: 11 단계, 이미지 2/2
    • Plug your lamp into an outlet and turn it on!
    • You will pull down on the chain to do this.
  12. Lamp Pull Chain Replacement: 12 단계, 이미지 1/1
    • Congratulations! You have fixed your lamp.
결론
Congratulations on fixing your lamp!
다른 3명이 해당 안내서를 완성하였습니다.
Anna Rill
회원 가입일: 11/07/18
304 평판
안내서 1개 작성함
Idaho State University, Team S1-G1, Watkins Fall 2018 Idaho State University, Team S1-G1, Watkins Fall 2018 회원
ISU-WATKINS-F18S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 4개
You saved my lamp! Thank you for this simple to follow guide.
Erica Chiovarou - 답글
All well and good, but isn’t it more likely that the break will be in the string which runs from the chain into the switch? This can be fixed by disassembling the switch itself - but where can one buy the right string?
gregg.horne - 답글
On my lamp, the problem was not the chain but in the switch itself. This made it necessary to replace the entire socket since the switch was riveted to its base. I made this video which shows how to replace the socket and switch:https://youtu.be/0fLnUPWzLeI
Scott Clark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 22
7일 전: 168
30일 전: 707
전체 시간: 26,524
