이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
Gently pull the socket from the base to expose the broken chain section.
Connect the chain with the chain connector to the broken chain on the lamp base.
Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp.
The chain will go down through this hole.
Screw the lamp shade back onto the base of the lamp by turning it clockwise.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
You saved my lamp! Thank you for this simple to follow guide.
All well and good, but isn’t it more likely that the break will be in the string which runs from the chain into the switch? This can be fixed by disassembling the switch itself - but where can one buy the right string?
On my lamp, the problem was not the chain but in the switch itself. This made it necessary to replace the entire socket since the switch was riveted to its base. I made this video which shows how to replace the socket and switch:https://youtu.be/0fLnUPWzLeI
Excellent, Thank you!
