주요 콘텐츠로 건너뛰기
Tonneau Trifold Bed Cover Retention Pin Replacement
필요한 것
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 1/3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 2/3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: 1 단계, 이미지 3/3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: 2 단계, 이미지 1/2 Tonneau Trifold Bed Cover Retention Pin Replacement: 2 단계, 이미지 2/2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 1/3 Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 2/3 Tonneau Trifold Bed Cover Retention Pin Replacement: 3 단계, 이미지 3/3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 1/3 Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 2/3 Tonneau Trifold Bed Cover Retention Pin Replacement: 4 단계, 이미지 3/3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: 5 단계, 이미지 1/2 Tonneau Trifold Bed Cover Retention Pin Replacement: 5 단계, 이미지 2/2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
결론
To reassemble your device, follow these instructions in order.
Christopher King
회원 가입일: 01/16/18
139 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 688
