주요 콘텐츠로 건너뛰기
Riddell Revolution Speed Football Helmet Facemask Replacement
필요한 것
  1. Riddell Revolution Speed Football Helmet Facemask Replacement, Riddell Football Helmet Facemask: 1 단계, 이미지 1/1
    • If the helmet has a visor remove this from the facemask first.
    • Visors are typically attached by screws to the facemask itself, although different models have different attachment systems.
    • The helmet shown in this photo does not have a visor.
  2. Riddell Revolution Speed Football Helmet Facemask Replacement: 2 단계, 이미지 1/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 2 단계, 이미지 2/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 2 단계, 이미지 3/3
    • Using the Riddell Quick Release tool (or a suitable alternative) press the center button of the quick release fastener to unlock the attachment.
    • Once unlocked you will end up with a washer from the back of the attachment and the top releasing mechanism.
  3. Riddell Revolution Speed Football Helmet Facemask Replacement: 3 단계, 이미지 1/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 3 단계, 이미지 2/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 3 단계, 이미지 3/3
    • Unscrew the top two attachments with a screw driver at the top of the facemask.
  4. Riddell Revolution Speed Football Helmet Facemask Replacement: 4 단계, 이미지 1/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 4 단계, 이미지 2/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 4 단계, 이미지 3/3
    • Slip off the four plastic clips and attach them onto the same spots on the new facemask.
    • The plastic clips for the top screws and the bottom quick release attachments are different so it is very important to keep them separate.
  5. Riddell Revolution Speed Football Helmet Facemask Replacement: 5 단계, 이미지 1/2 Riddell Revolution Speed Football Helmet Facemask Replacement: 5 단계, 이미지 2/2
    • Screw the top two attachments back at the top of the helmet.
    • Make sure the facemask is centered on the helmet.
  6. Riddell Revolution Speed Football Helmet Facemask Replacement: 6 단계, 이미지 1/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 6 단계, 이미지 2/3 Riddell Revolution Speed Football Helmet Facemask Replacement: 6 단계, 이미지 3/3
    • If necessary one might need to move the internal padding of the helmet to better access and maneuver these pieces.
    • Prepare to reattach the quick release attachments on the sides of the helmet by inserting the top releasing mechanism into the plastic fastener and aligning the back washer on the inside of the helmet.
  7. Riddell Revolution Speed Football Helmet Facemask Replacement: 7 단계, 이미지 1/2 Riddell Revolution Speed Football Helmet Facemask Replacement: 7 단계, 이미지 2/2
    • If necessary, make sure that the quick release mechanism is pressed, you may need to use the Quick Release tool.
    • Simply use your fingers to press together the back and front of the quick release attachments to lock them into place.
  8. Riddell Revolution Speed Football Helmet Facemask Replacement: 8 단계, 이미지 1/1
    • Lastly, if necessary reattach the visor.
    • If there is no visor to reattach, then the helmet is completed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kennedy Schull
회원 가입일: 09/19/18
211 평판
안내서 1개 작성함
University of Minnesota, Team S1-G7, Card Fall 2018 University of Minnesota, Team S1-G7, Card Fall 2018 회원
UMN-CARD-F18S1G7
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 55
전체 시간: 3,747
