주요 콘텐츠로 건너뛰기
Roof Shingle Replacement
필요한 것
  1. Roof Shingle Replacement, Roof shingle: 1 단계, 이미지 1/1
    • Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Use caution when handling a hammer and nails.
  2. Roof Shingle Replacement: 2 단계, 이미지 1/1
    • Remove the single broken shingle, carefully, without ripping out the shingles above.
  3. Roof Shingle Replacement: 3 단계, 이미지 1/1
    • Remove the adhesion strip off of the new shingle.
  4. Roof Shingle Replacement: 4 단계, 이미지 1/1
    • Slip the new shingle in place, and line it up where the old shingle previously was.
  5. Roof Shingle Replacement: 5 단계, 이미지 1/2 Roof Shingle Replacement: 5 단계, 이미지 2/2
    • Secure the shingle with three 7/8" roofing nails.
    • Be careful when hammering in the nails.
  6. Roof Shingle Replacement: 6 단계, 이미지 1/1
    • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
  7. Roof Shingle Replacement: 7 단계, 이미지 1/1
    • Press down the edges to lock the shingle in place.
결론
Marie Albrecht
회원 가입일: 01/19/18
145 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S59-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S59-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S59G1
1 회원
안내서 2개 작성하였습니다
댓글 2개
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - 답글
Yeah those 3 in 1s are definitely NOT good quality, they are old and soon to be extinct. (Good riddance)
OOtysweat97 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 417
