주요 콘텐츠로 건너뛰기
소개
A broken asphalt roof shingle will be repaired through this guide. Roof shingles, especially asphalt ones, wear and tear after years of sun damage, rain, and heavy wind. They need to be replaced because water can get under the broken shingle and cause the wood to rot or create a leak in the roof. The guide will be specific to repairing one tab of the shingle sections.
도구
부품
지정된 부품이 없습니다.
  1. Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Use caution when handling a hammer and nails.
  2. Remove the single broken shingle, carefully, without ripping out the shingles above.
    • Remove the single broken shingle, carefully, without ripping out the shingles above.
  3. Remove the adhesion strip off of the new shingle.
    • Remove the adhesion strip off of the new shingle.
  4. Slip the new shingle in place, and line it up where the old shingle previously was.
    • Slip the new shingle in place, and line it up where the old shingle previously was.
  5. Secure the shingle with three 7/8" roofing nails. Be careful when hammering in the nails.
    • Secure the shingle with three 7/8" roofing nails.
    • Be careful when hammering in the nails.
  6. Slightly lift the edges of the shingle and apply a thin layer of cement along it.
    • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
  7. Press down the edges to lock the shingle in place.
    • Press down the edges to lock the shingle in place.
결론
Marie Albrecht
회원 가입일: 2018년 01월 19일
145 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S59-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S59-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S59G1
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 139
