주요 콘텐츠로 건너뛰기
Fast Fix Screen Replacement
필요한 것
  1. Fast Fix Screen Replacement, Screen: 1 단계, 이미지 1/3 Fast Fix Screen Replacement, Screen: 1 단계, 이미지 2/3 Fast Fix Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Slide both battery latches to release cover.
    • Remove battery.
  2. Fast Fix Screen Replacement: 2 단계, 이미지 1/2 Fast Fix Screen Replacement: 2 단계, 이미지 2/2
    • Remove the M2.5 X 5mm phillips screw for the CD drive.
    • Remove the CD drive.
  3. Fast Fix Screen Replacement: 3 단계, 이미지 1/2 Fast Fix Screen Replacement: 3 단계, 이미지 2/2
    • Loosen 2 screws on access door.
    • They cannot be removed
    • Remove the access door.
  4. Fast Fix Screen Replacement: 4 단계, 이미지 1/1
    • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
  5. Fast Fix Screen Replacement: 5 단계, 이미지 1/3 Fast Fix Screen Replacement: 5 단계, 이미지 2/3 Fast Fix Screen Replacement: 5 단계, 이미지 3/3
    • Use a small screwdriver to press in the keyboard latches.
    • Remove the keyboard.
    • Unplug the keyboard cable at the ZIF connection.
  6. Fast Fix Screen Replacement: 6 단계, 이미지 1/3 Fast Fix Screen Replacement: 6 단계, 이미지 2/3 Fast Fix Screen Replacement: 6 단계, 이미지 3/3
    • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
    • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
  7. Fast Fix Screen Replacement: 7 단계, 이미지 1/1
    • Use a small flat screwdriver to pry the palm-rest off of the computer.
  8. Fast Fix Screen Replacement: 8 단계, 이미지 1/3 Fast Fix Screen Replacement: 8 단계, 이미지 2/3 Fast Fix Screen Replacement: 8 단계, 이미지 3/3
    • Remove the wireless antenna
    • Remove the LCD cable
  9. Fast Fix Screen Replacement: 9 단계, 이미지 1/1
    • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
  10. Fast Fix Screen Replacement: 10 단계, 이미지 1/1
    • Pry off the LCD bevel using a small flat screwdriver.
  11. Fast Fix Screen Replacement: 11 단계, 이미지 1/1
    • Remove the 4 M2 X 3mm Philips LCD screws.
  12. Fast Fix Screen Replacement: 12 단계, 이미지 1/2 Fast Fix Screen Replacement: 12 단계, 이미지 2/2
    • Unplug the screen cable and remove the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Carl Kangas
회원 가입일: 10/01/17
182 평판
안내서 1개 작성함
Michigan Tech, Team S3-G8, Galliah Fall 2017 Michigan Tech, Team S3-G8, Galliah Fall 2017 회원
MTU-GALLIAH-F17S3G8
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 6
30일 전: 23
전체 시간: 2,931
