주요 콘텐츠로 건너뛰기
2022 Chevrolet Silverado Windshield Wipers Replacement
필요한 것
  1. 2022 Chevrolet Silverado Windshield Wipers Replacement, Windshield Wipers: 1 단계, 이미지 3개 중 1개 2022 Chevrolet Silverado Windshield Wipers Replacement, Windshield Wipers: 1 단계, 이미지 3개 중 2개 2022 Chevrolet Silverado Windshield Wipers Replacement, Windshield Wipers: 1 단계, 이미지 3개 중 3개
    • Access the windshield wiper by lifting it away from the windshield.
    • Use a prying tool to lift the flat opening on the windshield wiper.
    • Caution: Be careful. Since you are working around glass and heavy tools, make sure there is enough clearance to avoid dropping tools onto windshield causing it to crack or scratching the vehicle.
  2. 2022 Chevrolet Silverado Windshield Wipers Replacement: 2 단계, 이미지 3개 중 1개 2022 Chevrolet Silverado Windshield Wipers Replacement: 2 단계, 이미지 3개 중 2개 2022 Chevrolet Silverado Windshield Wipers Replacement: 2 단계, 이미지 3개 중 3개
    • Use a pair of pliers if you are unable to lift up the flat opening with a prying tool.
    • Guide the broken windshield wiper downward to remove safely.
  3. 2022 Chevrolet Silverado Windshield Wipers Replacement: 3 단계, 이미지 2개 중 1개 2022 Chevrolet Silverado Windshield Wipers Replacement: 3 단계, 이미지 2개 중 2개
    • Once the windshield wiper is removed from the base, you are ready to insert the new windshield wiper.
    • The base should be cleared from any pieces of broken windshield wiper.
  4. 2022 Chevrolet Silverado Windshield Wipers Replacement: 4 단계, 이미지 3개 중 1개 2022 Chevrolet Silverado Windshield Wipers Replacement: 4 단계, 이미지 3개 중 2개 2022 Chevrolet Silverado Windshield Wipers Replacement: 4 단계, 이미지 3개 중 3개
    • Begin reassembling the new windshield wipers onto the base carefully.
    • Place the windshield wiper onto the base where the upright opening is, and assure it is secured to the base, as if you are hooking the item on.
    • Close the latch shut, pressing it down to secure placement.
  5. 2022 Chevrolet Silverado Windshield Wipers Replacement: 5 단계, 이미지 2개 중 1개 2022 Chevrolet Silverado Windshield Wipers Replacement: 5 단계, 이미지 2개 중 2개
    • Once the windshield wipers are secured back on, carefully set them back onto the windshield.
    • The installation of your new windshield wipers is complete.
    • Test the windshield wipers before using on the road.
결승점
작성자
1다른 기여자 명과 함께
Jessica
회원 가입일: 01/20/25
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 128
