주요 콘텐츠로 건너뛰기
Fast Fix Wooden Floor Panel Replacement
필요한 것
  1. Fast Fix Wooden Floor Panel Replacement, Wooden Floor Panel: 1 단계, 이미지 1/3 Fast Fix Wooden Floor Panel Replacement, Wooden Floor Panel: 1 단계, 이미지 2/3 Fast Fix Wooden Floor Panel Replacement, Wooden Floor Panel: 1 단계, 이미지 3/3
    • Peel up the floorboard with the hammer.
  2. Fast Fix Wooden Floor Panel Replacement: 2 단계, 이미지 1/2 Fast Fix Wooden Floor Panel Replacement: 2 단계, 이미지 2/2
    • Clean the floor and underneath the floor board tile.
  3. Fast Fix Wooden Floor Panel Replacement: 3 단계, 이미지 1/3 Fast Fix Wooden Floor Panel Replacement: 3 단계, 이미지 2/3 Fast Fix Wooden Floor Panel Replacement: 3 단계, 이미지 3/3
    • Spread wood glue on the bottom of the floorboard.
  4. Fast Fix Wooden Floor Panel Replacement: 4 단계, 이미지 1/2 Fast Fix Wooden Floor Panel Replacement: 4 단계, 이미지 2/2
    • Place the board on the floor and use hammer to tap into place.
    • Make sure there is no space in between the floorboards
  5. Fast Fix Wooden Floor Panel Replacement: 5 단계, 이미지 1/3 Fast Fix Wooden Floor Panel Replacement: 5 단계, 이미지 2/3 Fast Fix Wooden Floor Panel Replacement: 5 단계, 이미지 3/3
    • Place a heavy weighted object on top of the floorboard for a few minutes.
결론
Tyra Wooldridge
회원 가입일: 03/01/22
121 평판
안내서 1개 작성함
University of Memphis, Team 1-6, Cameron Spring 2023 University of Memphis, Team 1-6, Cameron Spring 2023 회원
UM-CAMERON-S23S1G6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 101
