소개
Repair is complicated because no spare parts could be found.
필요한 것
Opening the cover : push buttons on the left and right side. The right side has a coil to prevent opening under power and can get stuck.
Gently remove glued key panel
Remove 4 little screws behind the bottom of the panel
Turn laminator upside down and remove 6 bottom screws
When all screws are removed the inside cover can be lifted up
Remove the panels with led in front of the orange roll (sorry no picture).
You now have access to the inside
To measure the heating resistors detach the brown an blue wires leading to the roller assembly. Not the ones coming from the power cable and microswitches.
Ohmmeter result:
80 ohm : everything OK
340-350 ohm : main heating circuit (above and under black rollers) broken
100 Ohm : preheating (horizontally between orange and black rollers) broken
There are six screws fixing the motor and heating assembly to the bottom. (only two show in picture). Remove them and lift the assembly free
Heating elements are fixed on the left and right with two screws
And the resistor can be slided out.
This diagram helps detecting the faulty resistor.
I was unable to find spare resistors. But since I had two identical laminators, both with a broken resistor above the upper black roll, repair was possible.
Many thanks if somebody can point to a provider for these spare parts
다른 한 분이 해당 안내서를 완성하였습니다.
