주요 콘텐츠로 건너뛰기
Fellowes T7CM On, Off, Reverse Switch Replacement
필요한 것
  1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1개 중 1개
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Fellowes T7CM On,  Off, Reverse Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Fellowes T7CM On,  Off, Reverse Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Fellowes T7CM On,  Off, Reverse Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
  5. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: 5 단계, 이미지 1개 중 1개
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
  6. Fellowes T7CM On,  Off, Reverse Switch Replacement: 6 단계, 이미지 2개 중 1개 Fellowes T7CM On,  Off, Reverse Switch Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
결론
작성자
3다른 기여자 명과 함께
Michael Aldrich
회원 가입일: 10/12/16
686 평판
안내서 5개를 작성함
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 41
전체 시간: 3,781
