주요 콘텐츠로 건너뛰기
Fellowes T7CM Shaft Replacement
필요한 것
  1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1/1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Fellowes T7CM Shaft Replacement: 2 단계, 이미지 1/1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Fellowes T7CM Shaft Replacement: 3 단계, 이미지 1/1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Fellowes T7CM Shaft Replacement: 4 단계, 이미지 1/1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
  5. Fellowes T7CM Shaft Replacement, Gear and Shaft: 5 단계, 이미지 1/2 Fellowes T7CM Shaft Replacement, Gear and Shaft: 5 단계, 이미지 2/2
    • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
    • Remove the internal case.
  6. Fellowes T7CM Shaft Replacement: 6 단계, 이미지 1/1
    • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
    • This step may be unnecessary, but it will prevent the sensor from being damaged.
  7. Fellowes T7CM Shaft Replacement: 7 단계, 이미지 1/2 Fellowes T7CM Shaft Replacement: 7 단계, 이미지 2/2
    • Remove the six screws on the gearbox.
    • Remove the gearbox cover to expose the gears.
    • The screw length is 34 mm and the head diameter is 7 mm.
    • The screw length is 26 mm and the head diameter is 7 mm.
  8. Fellowes T7CM Shaft Replacement: 8 단계, 이미지 1/3 Fellowes T7CM Shaft Replacement: 8 단계, 이미지 2/3 Fellowes T7CM Shaft Replacement: 8 단계, 이미지 3/3
    • Remove the gears.
    • The larger gear located in the middle may require a screwdriver to pry off.
    • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
  9. Fellowes T7CM Shaft Replacement: 9 단계, 이미지 1/2 Fellowes T7CM Shaft Replacement: 9 단계, 이미지 2/2
    • Remove the pin in order to pull the casing off of the shafts.
    • Remove the casing in order to expose shafts.
  10. Fellowes T7CM Shaft Replacement, Shaft: 10 단계, 이미지 1/1
    • Remove the metal attachment that holds the two shafts together.
  11. Fellowes T7CM Shaft Replacement: 11 단계, 이미지 1/1
    • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Michael Aldrich
회원 가입일: 10/12/16
686 평판
안내서 5개 작성하였습니다
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 1,186
